Hi -
I'm hoping I posted this in the right place. We have a 2004 Casita trailer with a gas-fired furnace -- a Suburban NT-12SE -- that does not consistently light, except when I remove the front cover, in which case it lights all the time (so far, anyway).
The start-up sequence is normal -- the fan starts, the gas valve opens (because I can small gas outside the trailer by the furnace vent), and then I hear a clicking sound, which I presume to be the ignitor firing. It tries to ignite 3 times, and when it doesn't light, the fan shuts down. When it does light (not very often), the furnace operates normally.
Looking through the sight glass, I can see when the spark should be, and when it lights, including when the cover is off, I can see spark. When it fails to light, I cannot see spark in that same place -- so that seems to be the source of the problem.
The intake and exhaust vents are both perfectly clear.
I checked the ignition wire (at least the part that i can get to), and it appears fine -- insulation shows no sign of degradation or cracking. But just for heck of it, I slid a thick piece of insulative sleeving over the wire, but that did not change anything.
Any suggestions as to what might be the problem? It's cold at night where we camp!
Many thanks,
Dave
