Tires rubbing on camper 2 inch clearance ?
fowlthing
Bought trailer used. Have now noticed wear of tires against bottom of trailer.
Springs are above the axles.
Was this caused most likely from a flat tire rubbing the bottom or is clearance not enough?
Would stronger springs help??
Any ideas? Is best bet TPMS system to lesson chance of blowout or flat ??
Thanks
2017 Ford 350 SRW
Grand Design Solitude 375RES
may switch to a Ram
19 REPLIES 19
shelbyfv
Are you saying the tires are rubbing now or that it looks like they have rubbed in the past? All tires, some tires, one tire?? I like my TST TPMS. It shows temp and pressure.
fowlthing
Tires and rims are per factory sticker.
Springs look flat to me. But just a guess
On my part.
2017 Ford 350 SRW
may switch to a Ram
time2roll
I assume replacement springs are needed. If spending money I would go up some in rating.
MFL
Nomad II
Nomad II
If the springs look somewhat flat, replacing with heavier will help.
Oversize wheels/tires...maybe, but clearance is the issue. Normally 2"s in not enough, but most times 3"s is sufficient.
Jerry
bgum
Possibly from wrong size tires and rims.
