Hello all-
Recently completed a bearing pack, bearing seal replacement, and brake adjustment. I can't imaging the heat being caused by the bearing grease packing.
Hub adjustment:
Hubs were tightened, then loosened a little so that wheel spun freely and there was no play in hub when moved in/out.
Brake adjustment included:
Backed out shoes from adjustment port to where the brakes locked up. Then backed out about 5-7 clicks to where there was a mild scrape/sound feel.
I tested brakes by driving around under tow for approx. 5-10 miles braking hard and also using my Tekonsha brake lever to brake hard (not at the same time). I did hard braking doing 30-40mph. I did this to adjust my Tekonsha gain setting and to be sure brakes did not lock up on a hard stop.
After the drive, I pulled over near my home and went back to touch brake drums. They were very hot to the touch...all 4.
Can the slight drag from adjustment be the cause of the excessive heat?
Is it from the hard braking several times?
If drums are hot from not adjusted properly (tad too open), would the 5-10 miles of hard braking and hot drums have caused damage to anything?
Thanks!
2023 GMC, 3500HD, Crew Cab, 6.6L Gas/6 Speed Auto, 4X4, Standard Bed; SRW
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
