TV mount question
az350x
The previous owner of my "new" TT removed both the TV and the wall mount, leaving me with only the spin-around TV carousel. The opening will accommodate a pretty decent-sized TV, but since I have no manuals and nothing but three screwholes in the box for reference, I have no idea what style of mount to use, or how heavy of a TV I can get away with.
Help? ๐Ÿ™‚
Thanks!
Pack out MORE than you packed in!!
2001 Ford F350 Crew cab short bed 4x4 Powerstroke
2013 Forest River Surveyor SV305
5 REPLIES 5
Ole_Man_Dan
Caveman Charlie wrote:
If your TT is not too old. (And , it sounds like it isn't) You might be able to contact the manufacture or talk to a dealer of that model and get a idea. Might get lucky and see a new one setting on the lot with the same type of TV mount and then you can go look at it.
I fixed my TV to a piece of Plywood also.
A little stain and it's the same color as the flimsy wood was.
It's strong...
Caveman_Charlie
1993 Cobra Sunrise, 20 foot Travel Trailer.
westend
IIRC, my new LED 32" flatscreen weighs 8 lbs. I used a tilting swivel screen mount like this. The mount is secured into a 5/8" piece of plywood that is attached to the wall and studs of the trailer.
'03 F-250 4x4 CC
az350x
My enclosure is a box in wall between bedroom and living room that is 4" deep, and swivels 180* to allow viewing from either room. So, I need to stay both shallow and lightweight. Box is about 35" wide by 20" tall.
Artum_Snowbird
The best thing to do is to build a secure backing mount for a swing arm. This might mean you have to have a floor board secured, and then another bracket at 90 degrees so you have a vertical piece to put some screws into. Once you have the back mount solidly connected to the walls and joists then you can get a quality swing bracket to put your TV on. New TV's are so light, just tie it down when you travel and the mounting platform will not come loose.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
