The seven pin plug needs to be plugged into a seven pin plug on your truck to get power for the interior light. You are using an adapter that does not have a 12 volt power wire.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
