Utah 39
grouchrc
i have to travel Utah 39 from Huntsville to US 30 in Wyoming en route to Jackson Hole.
Anny problems with a 34 ft 5th wheel?
2002 Dodge 3500, Diesel, Auto, 2wd 4.10 rear,EGT/Boost & tranny gages,aFe Air filter,Jardine 4" exhaust, BetterBuilt boxes.. Master Brake Controler. 33ft AutoMate 5th wheel
4 REPLIES 4
GaryUT
You should be fine.
The hardest part is the 7 miles between Ogden and the Pineview dam on your way to Huntsville, this is the narrow twisty road that TexasShadow mentioned.
Gary
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
grouchrc
August, 2014
GaryUT
When are you planning the trip?
UT 39 from Huntsville to Woodruff is closed for the winter, usually opened my memorial day depending on snow depth. It's not a bad road, some turns and switchbacks, the summit is around 8980 feet.
Gary
TexasShadow
My Mountain Road directory says that this road is mostly good, but passes through a 5 miles long canyon that is curvy and very narrow with rock cliff on one side and concrete curbs on the other and is just barely wide enough.
So that sounds not so good to me. Sorry.
TexasShadow
Holiday Rambler Endeavor LE/ 3126B Cat
Sometimes BMW K75 on Rear Carrier
Jeep Grand Cherokee or 2016 Ford XLT 4x4 super cab with 8 ft bed
M&G aux brake system
854 Watts of Solar Power
Always remember you're unique, just like everyone else.
