12 volt mattress pad warmers
naturist
A couple years ago there was a thread on this forum about 12 volt mattress pad warmers, and as it turned out, nobody was making them anymore in any sizes except very small. Those of us with full-size or larger mattresses were out of luck.
I've just discovered that ElectroWarmth has them available again at http://electrowarmth.com/shop/
We use a 120 volt one at home and love it. The room temperature can drop down in the 50s and we stay toasty under the covers. But that mattress pad warmer will not work on a MSW inverter, so we either have to stick to shore power when camping where we need that heat, or we have to run the generator all night (nope, not gonna happen).
I sprang for the full-size queen pad with dual controls, and while it was spendy at $202 with shipping, I think it'll be worth it. It draws a max of 3 amps, and will save us on propane on those cold nights when we don't need to run the furnace to stay warm in bed.
I dunno why they reintroduced them, or for that matter why they discontinued them earlier, but TODAY they are available again. Get yours while the gettin' is good.
18 REPLIES 18
pnichols
Try this link. It appears that this supplier and their 12V heating blankets/pads are alive and well. Note that whatever amperage power draw they list may not be a continuous amount ... as they probably cycle ON/OFF all night so their average amperage power consumption could be less than the running-amps value they list:
http://www.12volt-travel.com/12-volt-electric-blankets-c-90.html
2005 E450 Itasca 24V Class C
naturist
Bummer, guys. Turns out that somebody put up the wrong info, and they are NOT making new 12 volt ones after all. I called them this morning to confirm, and indeed, the page is wrong, they are 120 volt. I suggested that it may be time to make 12 volt ones again, but of course, the gal I talked to is not who makes that decision.
camper19709
Thanks 2oldman. I sorta thought air circulation was the solution but thought I would ask.
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
2oldman
camper19709 wrote:
I will add a question here if I may. I have moisture/dampness under my regular mattress. It is between the regular mattress and the plywood platform. My question is: if I put a 12volt mattress pad there will it help keep the area dry?
No. You should be addressing the cause, like too little air circulation.
camper19709
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
MrWizard
Moderator
Moderator
We have a 120v mattress pad
But switched to a 120v electric blanket
Simple reason, the pad underneath us meant to much warmth, the memory foam heat sensitive mattress couldn't adjust to us
the blanket uses a little more power
But we sleep better (during cold weather) using the blanket
As the mattress responds better to our bodies, without the extra heat between us and the mattress
I can explain it to you.
1997 F53 Bounder 36s
2oldman
naturist wrote:
e. The 120 volt one in the sticks and bricks is only 60 watts,
Brand?
eb145
The "soft heat" brand heated mattress pads work fine on MSW inverter. I have a queen sized one with dual controls in my TT. It worked so well we got one for our King size bed at home also.
The controllers for my "soft heat" brand mattress pads looks like this:
Each controller has a transformer that has no problems with MSW inverters.
One soft heat mattress pad on Amazon
Ed
naturist
kaydeejay wrote:
naturist wrote:
.....................It draws a max of 3 amps, and will save us on propane on those cold nights when we don't need to run the furnace to stay warm in bed.................
3 amps at 12V is 36 Watts.
Not going to keep you toasty I'm afraid.
I think I disagree. Not with your calculation, with your conclusion. You are right, it is only 36 watts. The thing is, mattress pad heaters do not need to be as powerful as electric blankets, because they aren't out in the open air. They are well insulated on the bottom, as well as above. The 120 volt one in the sticks and bricks is only 60 watts, and I never use it above a 2 (out of 10) setting.
But I will be sure to let everybody know how well it works after it arrives.
naturist
Did you actually speak with somebody at ElectroWarmth who confirmed they have the 12V queen size mattress pads again?
It appears to me that the all of ElectroWarmth "mattress pads" are 110Vac, and only their "bunk warmer" is 12Vdc... I did see the sentence on the queen page that says 12V, but I suspect it's a typo' ๐Ÿ˜ž
-Mark
I did not speak to anyone. But a year or so ago I went to that web site and saw no 12 volt queen sized pads at all, so this is a "new" page on that site. But if it turns out to NOT be a 12 volt pad when it arrives, it'll go straight back. I'll be sure to let y'all know either way.
profdant139
We have discovered that even when the interior of the trailer is in the low 20s (yes, we have a thermometer), we are fine without any heat source during the night -- just a thick down comforter and a couple more blankets on top of that. The problem is getting out of bed in the night and in the morning -- we wear Russian lamb's wool hats and lots of warm clothing. And yes, that is a buildup of ice on the inside of the window behind DW:
How cold does it get? Once, the cord on our coffee maker froze -- this is not a trick shot:
On second thought, that 12 volt bed warmer is sounding pretty good!
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Calisdad
LenSatic wrote:
We use this:
Don't even have to plug it in. ๐Ÿ˜„
LS
We have a couple like that but my wife hogs the heat controller.
LenSatic
PawPaw_n_Gram wrote:
LenSatic wrote:
We use this:
LS
What do you do if it is a 3 Dog Night ?
Sleep on the floor. ๐Ÿ˜‰
LS
2008 Casita SD 17
2006 Chevy Tahoe LT 4x4
2009 Akita Inu
1956 Wife
1950 LenSatic
PawPaw_n_Gram
LenSatic wrote:
We use this:
LS
(Yes, that's what the band is named after).
Full-Time 2014 - ????
โ€œNot all who wander are lost.โ€
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
