Mar-18-2014 06:06 AM
Aug-26-2022 07:10 AM
Aug-26-2022 06:04 AM
Mar-21-2014 12:45 PM
S'more campers wrote:
Doubling up on your filters (parallel) would significantly increase the beta rating, reducing wait times at the fill station. Probably a bit of a pita to setup, but better than being 'that guy' at the fill station.
Mar-21-2014 10:51 AM
down home wrote:
I'fe got one ceramic filter that .09 micron but doesn't flow great and is a bear to clean. So...I'm going to order a 10x4 ceramic off the net. They will get all the nasties and use the other filter for pre filtering sediment etc.
Mar-21-2014 10:25 AM
Mar-21-2014 09:04 AM
Mar-21-2014 07:51 AM
down home wrote:
The blue filter from Cw for the 10x2.5 filter has very good specs but won't flow a much as we like. It does pretty well though.
Mar-21-2014 06:29 AM
Mar-20-2014 11:26 AM
myredracer wrote:I was referring to filtering the water going into you your FW tank. At 2 gpm that would take 200 mins to fill a 100 gal FW tank. You would have a lot of folks waiting in line.Gjac wrote:
Remember each filter that you add will produce back pressure and slow the filling process.
Sorry, but that's not quite true. That can be the case but it depends entirely on the filter cartridge size and the specifications for the particular filter(s). Some have excellent flow rates and low pressure drop. I haven't measured it yet, but I am probably getting about 2 gpm after 4 filters despite the last filter being 0.2 microns (absolute). That is pretty dang good and waaay more than needed to fill a drinking glass (which the last filter is for).
When choosing a filter(s), it really pays to look closely at their specs.
It also depends a lot on the regulator you have. I've got a Watts 263A regulator good for up around 5 gpm, compared to the basic inline ones at around 1 gpm. You'll have higher pressure drop through an inline regulator too.
Mar-20-2014 10:37 AM
Mar-20-2014 07:44 AM
mikestock wrote:This is what I have evolved to also. Remember each filter that you add will produce back pressure and slow the filling process. I traveled with a guy that had 3 filters it took forever to fill his 100 gal tank while a line of people were waiting to fill and dump. Also if you stay at more remote CG's and try to use a "water thief" to fill, it will blow up like a balloon due to back pressure. I have used a filter while staying at lakes in Canada where the water is drawn from and they can clog up in a week or so, but have not had any problems with city water in any of the states you mentioned. But I'm old and still drink from and fill my tanks when home with a green garden hose.
After years of filtering every drop of water I finally went with a under the counter filter for the kitchen cold water. That takes care of all of the water we use for cooking and drinking. I use bottled water in the bathroom for brushing teeth. The rest, I don't filter.
Mar-20-2014 07:31 AM
Mar-19-2014 10:07 PM
Mar-19-2014 05:52 PM
