atwood 7920-II FURNACE ONT IGNITE, fan comes on,no clicking then shuts off,
thegolfer
Visitor
Visitor
i changed sail switch,temperature control switch and circuit board ,still wont ignite ,help whats net to try
1 REPLY 1
bid_time
Nomad II
Nomad II
Sounds like itโ€™s likely the igniter or the flame sensor. Another remote possibility is the high-limit thermostat.
You have probably already spent more than it would have cost to have a Tech diagnose the problem. Itโ€™s time to stop throwing parts at it and use a multimeter and find the problem - then apply the fix. The sequence of operation should be in the Ownerโ€™s Manual. Use it along with a multimeter to find what is happening and where the hang up is.
