Class A LP Tank
haste_maker
I am thinking about trying to put a "T" in my LP line @ the LP tank, has anyone else done this on a Class A ? If so did you have problems doing this ?
Retried Teamster
2007 Allergo
4 REPLIES 4
RLS7201
fyrflie wrote:
If you prefer low pressure, make sure that none of your appliances (i.e. Firepit, BBQ, Etc.) do not have a regulator attached.
Propane does not like to be double regulated.
Look closely at the propane regulator on your RV. It is a two stage regulator. Then on the propane stove in your RV is a third regulator.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
fyrflie
haste_maker
Low pressure to use outdoor grill & fire pit...shut off is a good idea...thanks
Retried Teamster
2007 Allergo
GASMAN6674
You want high pressure? or low pressure? If you want high pressure you can either add a tee and a couple nipples by removing the POL fitting. Low pressure you can tee in anywhere downstream of the regulator. I would highly recommend that you add a shut off at your tee for your branch line.
Jim & Debbie England
Do you have Gas? Propane Exceptional Energy
2015 F350 CCLB 6.2L/4:30 Vermilion Red
2020 Cougar 364BHLGone but not forgotten 2012 Ridgeline 34RLT fifth wheel/2012 V27FK V-Cross TT
