โOct-05-2018 09:35 AM
โOct-10-2018 04:32 PM
โOct-09-2018 08:15 PM
โOct-09-2018 07:16 PM
jjrbus wrote:
Again thanks for the responses always appreciated.
I purchased the aluminum gas cap sold online. After only a couple uses the gasket/washer ripped. I contacted the seller and he replied with a list of other things he has for sale! It is a 1 3/4 inch washer which is not readily available anywhere. Lesson learned, will recommend modifying the Honda cap for others.
So far I am not having any vacuum issues, I cannot measure the vacuum and barely see fuel in the line but it keeps working so will stick with this for now and keep other options in mind.
I also want to experiment with how high the Honda can raise fuel.
I have my Honda in a box so the goofy new fill spouts do not work, I use a automotive transmission funnel to fill it. Plus the new improved spout broke after only a few uses.
โOct-09-2018 06:19 AM
Lynnmor wrote:
Don't use those stupid gas cans that require pushing the nozzle against the Honda fuel tank. They can indent the soft plastic and cause a vacuum leak.
โOct-08-2018 05:19 AM
โOct-08-2018 04:26 AM
โOct-07-2018 07:59 PM
jjrbus wrote:
Thanks for the responses. I give up trying to make sense of it.
I started with a 1/4 ID hose and the genset would occasionally run out of gas, even though there was gas in aux tank. I took a guess and tried the 3/16 ID line and it is working fine.
As long as there is enough fuel in Honda to start it will draw gas from aux tank.
At idle I see almost no gas in line, there are some bubbles coming out of hose in tank. On high the fuel line may or may not fill up with gas, no rhyme or reason to it.
All I can figure is it works, so I will leave it alone until it quits working!
โOct-06-2018 09:24 AM
โOct-05-2018 07:45 PM
โOct-05-2018 06:11 PM
โOct-05-2018 10:38 AM
