โMar-31-2021 08:39 AM
โOct-26-2021 06:47 AM
time2roll wrote:
Not really an expedition vehicle. Not likely to be in Canada in winter.
โOct-26-2021 01:25 AM
โOct-25-2021 06:54 PM
โOct-25-2021 06:39 PM
time2roll wrote:
Currently I have it set for 35F on, 45F off. Will see how it goes. Thinking about going 38 to 42 or similar.
Not sure it is a huge deal to be exactly something to be perfect.
โOct-25-2021 04:48 PM
โOct-25-2021 03:21 PM
โOct-25-2021 12:59 PM
โOct-08-2021 06:06 AM
โOct-07-2021 08:10 PM
โOct-07-2021 07:25 PM
โOct-07-2021 07:09 PM
time2roll wrote:StirCrazy wrote:My BMS cuts charging at 1C and discharge at -10C.
I was thinking about this at work, and I may be wrong... it all depends on the BMS and how it is configured for the internal pass through of power. if it is just one line then the cold weather will kill the whole battery, but if they spent some money and used diods and did two internal paths then you could controle charging and discharge independently. I guess we would have to dig into the BMS construction to know for sure...
Steve
โOct-07-2021 06:40 PM
Steve
โOct-07-2021 05:16 PM
time2roll wrote:Ivylog wrote:Almost too good of a price. Please update when you get them.
I just paid $350 for 8-280AH cells and $370 for 8-310AH cells.
โOct-07-2021 04:02 PM
StirCrazy wrote:time2roll wrote:Itinerant1 wrote:Heaters will be wired on the load side of the BMS. If the load side is powered by generator, solar or vehicle, the power will go to the battery heater.
If the heating pads are wired directly to the batteries terminal and if needing them because the actual cells are below 32f and not the ambient temp how would a generator help unless you have a heater cube plugged into it throwing heat to the compartment.
Are you going to add extra insulation on the walls/ floor to help keep heat in and cold out during the colder months if using them during that period?
Insulation will not be added unless it seems to be needed. Most camping is in fair weather. Not intended to be a north pole expedition vehicle. Just some minimal protection for a mild cold snap.
I think everyone is going on about a mute issue, unless the batteries are totaly dead then just the charging is going to be cut off at 32 degree ish, the discharge will still be available so the heating pads will work untill it gets down to a heck of a lot colder. if you insulate good around the batteries you may never come to this as the discharge from using/charging the batteries will create there own internal heat and with the right insulation it might be enough to keep them above zero down to a pretty cold temp, but that just theory...
Steve
