โJul-08-2014 04:43 AM
โJul-09-2014 05:27 PM
โJul-09-2014 05:27 AM
robatthelake wrote:
Since the Storage Bays are attached to the Slide ,would it not make sense to drill up through the top of the Compartments? You still need to have some steel reinforcement .
โJul-08-2014 11:40 PM
โJul-08-2014 10:57 AM
robatthelake wrote:
You would need to add some Steel plates below the Floor and run carriage Bolts UP through the plates and through matching holes in the Pedistal .
This could be accomplished with the Slide Extended on My Rig! As long as the Plate and Bolt Heads were kept to the minimum and don't interfere with the Slide mechanism it should be a piece do Cake.
Driving Lag Bolts in from the Top would not work for Me. Just not enough solid wood to get a secure grip!
You would also need to determine if Seat Belts could be added!
โJul-08-2014 10:43 AM
dockmasterdave wrote:
Google Hilti togglers. They might be a good fix for this and also come in stainless.
โJul-08-2014 09:42 AM
โJul-08-2014 08:22 AM
