rear end ladder
Judo_x-ray
Hi everyone, I need some ideas. I want to install a ladder on the back of my cherokee 2003 25 ft. fifth wheel. It did not come with a ladder. Any suggestions as to brand,easy install etc. Thanks for the input.:)
6 REPLIES 6
scbwr
Ditto on checking with manufacture. After buying my 2002 Sunline, I inquired about adding ladder and was informed that the back wall did not have the bracing for it unless ladder was ordered prior to construction. I just contacted Winnebago about adding a ladder to our new 2201DS. Reply from Winnebago was that a ladder can be installed but will void my warranty. I've responded by asking if it's possible to have it done at the factory and does having a dealer install it void the warranty.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
Tin_Pusher
Something else to think about...
Does your camper have a "walk-on" roof? Mine has the ladder, but not the walk-on, have to put plywood down to get around up there. Limited usefulness:(
Tin Pusher's Guide To Successful RV'ing: "Don't get mad, don't get in a hurry"
2002 1500HD
2002 Wilderness 265H
1997 Seadoo GTI
1952 Wife;)
n7bsn
What they said.....
Judoka?
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
robsouth
Some campers are "prepped" for ladder installation and some are not. Find out if your is prepped or figure something else out.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
Dtaylor
Contact your manufacture and ask for diagram showing stud location in your back wall. They should be able to email it to you.
Our Travel Blog
2018 Premier 29RKPR
2014 Ford F-150
agesilaus
You better see what is behind that back wall first. The ladder has to have solid support or the fasteners will pull out.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
