Replacing patio door with French doors
Gutasyfamily
We need a wider door to get our daughters wheelchair thru, we have an opportunity to purchase a camper
To replace our sprinter that has a patio glass door, it doesn’t quite open quite wide enough we thought French doors
Would
Work perfectly anyone ever done that it’s a 2013 keystone hideout
2 REPLIES 2
LouLawrence
There are also some commercially available devices to allow you to raise and lower folks from your RV without the use of ramps and wheelchairs. You could then have a wheelchair inside and outside or a foldable unit. Obviously, I don't know anything about your situation but just a thought about an option.
bucky
Are the French doors going to block further access to the interior when they are open to allow entry? Maybe a different wheelchair would work.
Puma 30RKSS
