โApr-13-2018 03:17 PM
โApr-14-2018 10:12 AM
time2roll wrote:theoldwizard1 wrote:Done:
Achieving proper multi-step charging will be the BIGGEST problem to solve !
http://www.bestconverter.com/DLS-Series-24-Volt_c_145.html
โApr-14-2018 07:12 AM
jplante4 wrote:2nd post.. his reply to you.
There was nothing in the OP's OP that mentioned tent camper.
โApr-14-2018 06:33 AM
drsteve wrote:
You seem to be saying that because the OP is a tent camper rather than an RV owner, he's not supposed to have an opinion on generator use? That if he owned an RV his attitude would NOT be judgmental and prejudicial?
โApr-14-2018 06:19 AM
jplante4 wrote:
I didn't see any reference to LOUD generators. That debate has raged here several times and usually results in a closed thread.
I would remind all the generator haters that there are several reasons to run a generator. Just ask anyone who uses a CPAP how they get by of solar only. Don't get me started on the Keurig users. When someone who doesn't own an RV writes " I HATE when other campers run their generators for 12 hours out of the day, & I refuse to be one of them.", that's judgmental and prejudicial.
โApr-13-2018 08:15 PM
โApr-13-2018 07:58 PM
jplante4 wrote:Maybe so, but it's how most people I've dry camped with feel about it. If you have special power needs I think it behooves you to invest in enough batteries to get through the night. I really don't think that's a big imposition on ONE person who otherwise disturbs the entire campground.
โApr-13-2018 07:31 PM
MrWizard wrote:
but how will you charge the 24v bank, solar ? special charger from 120v ?
special add on 24v alternator for the engine ?
โApr-13-2018 07:20 PM
pianotuna wrote:
Hi,
It would be best to get the RV before purchasing solar panels that may not fit.
As for power--make a wants vs needs list. For example I want to run an induction hob, but I NEED to run the furnace.furyous68 wrote:
I was actually looking at a 600w system w/ monocrystalline cells & a 60A mppt controller. It's only 4 panels. When I get the RV, I'll see if I have room to put another 2 panels on top.
โApr-13-2018 07:03 PM
โApr-13-2018 06:30 PM
furyous68 wrote:No, amperage only determines how long it takes. You must be pumping 28.8 volts into it, which means your solar must be something greater than that.
I think I read that you need to generate at least 35A from the panels to charge a 24v battery... is that right?
drsteve wrote:Agree.
I and most others would suggest that the inconsiderate dolts who run loud generators all day are the ones who don't belong.
โApr-13-2018 06:29 PM
jplante4 wrote:
However, if you're already passing judgment of how other people pursue their recreation, maybe this isn't the lifestyle for you.
โApr-13-2018 06:28 PM
โApr-13-2018 06:00 PM
โApr-13-2018 04:32 PM
โApr-13-2018 04:29 PM
time2roll wrote:
To be independent you need more battery, not less. To get more from solar or from the dreaded generator consider a lithium battery. Going to be a bit extra up front but could be the last battery you buy.
Yes for a larger system going 24 or 48 volts will have an advantage. I assume you are thinking 800+ watts solar.
Yes you can get a DC/DC converter to power the 12v accessories. I recommend Victron.
