Apr-20-2018 04:49 PM
Apr-22-2018 10:10 AM
DiskDoctr wrote:
I believe you have that backwards....
XPS (blue/green/pink at big box stores) is considered non-absorbing and EPS (white) is water absorbing.
Owens Corning XPS vs EPS water absorbing foam
Apr-22-2018 06:20 AM
Apr-22-2018 06:12 AM
myredracer wrote:agesilaus wrote:It will depending on type. The open cell rigid expanded polystyrene XPS type absorbs moisture and moisture migrates through it. It's the white stuff disposable coffee cups are made from. It's the type that is used in exterior walls of RVs and is a really bad choice because of moisture migrating through exterior walls to a cold exterior skin and condensing.
Styrofoam absorbs water?
Closed cell rigid extruded polystyrene EPS type does not absorb moisture and cannot migrate through it and acts as a vapor barrier. It's the pink or blue or sometimes green stuff you see in building supply places. It is denser and has a much higher R-value but is more expensive and is why it's not used in RVs.
Both types come in spray or rigid sheet versions. A better rigid or spray foam is icynene which has a higher R-value but costs even more. It's not fun to work with and makes a nasty dust when cut.
Apr-22-2018 05:33 AM
rexlion wrote:
Icynene is a type of urethane foam, but not dense so it could absorb water. Application of sprayed urethane is a pro job for someone with the proper sprayer and equipment, not really geared toward DIY, but it (the dense variety) is very good insulation.
EPS will work well too.
I assume you will attach the coroplast with hardware? Those sheets are tough to get glue to adhere... even the specially etched sheets.
Apr-21-2018 09:35 PM
Apr-21-2018 05:31 PM
Apr-21-2018 11:03 AM
Apr-21-2018 10:50 AM
Apr-21-2018 09:37 AM
Apr-21-2018 08:49 AM
Apr-21-2018 08:19 AM
Apr-21-2018 06:55 AM
SteveAE wrote:
Dan,I would suggest something other than "Styrofoam" though as, if/when water gets up there, Styrofoam will tend to absorb it.
Apr-21-2018 06:29 AM
Apr-21-2018 05:57 AM
