04 Cougar M301 bhs by keystone
Socom
Just bought this 04 cougar travel trailer. Slide out is only working on battery. I disconnected the battery, plugged up to service and slide doesn't work. Is this supposed to be like this or not.Any suggestions on where to start looking for the issue would be helpful.
21 REPLIES 21
MFL
Nomad II
Nomad II
Too many variables to give correct answer. It depends on size of battery, age of battery, how many times it has been at 50 percent charge or less. The battery will quit operating the slide, before it is dead. It will still run some things, but moving a large slideout is a heavy draw. A questionable battery should be replaced.
Jerry
Socom
How many times should a fully charged battery move slide in and out before it's dead.
Socom
Thanks all for the valuable information. I apologise for posting in wrong area and thank you for moving thread to correct place.
JKJavelin
No need to disconnect the battery. Leaving it connected while plugged in will keep it charged up.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde AllTrek 4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 106 Nights
MFL
Nomad II
Nomad II
Yes, that is normal, often times the converter alone will not have enough power to operate a slide. It normally takes a well charged battery.
Welcome to the forum! As you can see, there are certain areas to post in, that will get the best replies.
Hope you enjoy the new to you trailer! ๐Ÿ™‚
Jerry
1492
Moderator
Moderator
Moved from Forum Posting Help and Support
2012Coleman
Start by posting your question on the Travel Trailer forum - this one is for help with posting or other forum issues.
2018 RAM 3500 Big Horn CTD
