2003 Arctic Fox 24' 5th wheel
Liane01
Would anyone know where the grey water valve is located on this model? I need to replace it, but when I follow the pull lever, it
appears to be wedged behind the steel frame and appears to be unable to access. It is a 4 season unit and I really don't want to cut
a bunch of holes in the underbelly. If anyone has an idea, please
share. Thx
1 REPLY 1
agesilaus
You may want to ask on the arctic fox/Northwood owner's forum which is NROA Forum
I have a 2016 and like you the line goes into the underbelly. If you get some good tape, Eternabond or some of the Gorilla underbelly tape, cutting a flap into the coreflex is no big deal, you just tape it up afterwards. Leave one side of the flap attached as a hinge.
If you have to get to the valve you will be doing that anyway. There is no way around it unless you remove the whole coreflex sheet.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
