2016 raptor lippert jacks stuck
sean425
I had to move my 5er out of the driveway today, I got it to the street, got the front jacks down to remove the TV.
After this the control panel for the jacks went down. Screen shows nothing.
Battery charged, also tried with generator running. I checked all the fuses on the breaker panel, and took the display cover off to assure the connection was good with the connector to the display screen.
I called camping world, they told me to read the owners manual about a manual over ride, but there's nothing there and lippert is closed. Ideally i would like to lower the 5er first thing in the AM to get back to camping world.(tech said he could squeeze me in first thing).
Unit it is 2 weeks old.
Has anyone done the manual over ride for this model? Or maybe a fuse I'm missing ?
12 REPLIES 12
momentum_rv
It is nice to hear the outcome for future use...
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
minnow
Well folks another forum hit and run. Comes here looking for advice never to be heard from again.
railrode1
Does the backlight still work on the display? On mine, the lcd module went bad but the buttons still functioned.
2013 Keystone 3900FB
2017 F-350 Lariat CC 4X4 6.7 Diesel
Gsport
On your phone, look up the App "myLCI".. It's lipperts app about everything lippert. Lots of great information there. You'll probably find your answer there
Allworth
A 30Amp Buss fuse somewhere behind the driver's side landing gear leg??
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
sean425
I checked the connection going to the controller, it was good.
Dick_641
My momentum also has a inline fuse up front in the generator compartment that runs the six point leveling system
momentum_rv
Also, there is a plug on the back of the controller... Maybe loose?
momentum_rv
That's cuz phones are for talkin' on ๐Ÿ˜‰
sean425
Thanks momentum, for some reason I coudlnt find that page on my phone.
momentum_rv
Maybe this will get you going
http://lci1.com/assets/content/support/technical-information-sheets/0262.pdf
agesilaus
There may be an overide switch. My 5ver has a switch in the basement that cuts the power to the jacks to prevent an unauthorized someone from operating them
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
