3/4 Ton Towing fifth wheel
dennych1
I am interested in seeing what fifth wheels people tow with 3/4 ton SB. I am looking to upgrade my fifth and it is heavier.
Thanks for the help
Dennis
100 REPLIES 100
rhagfo
Me Again wrote:
Cummins12V98 wrote:
Chris
What does your combo weigh?
When I towed with my 98 12V Cummins 2500 4X4 my combined weight was 20,500# the RV was a 2002 32.5' Avion Platinum. The truck sat level without air bags. I ran stock 3rd gen tires and wheels. Can't find my weight slips but it handled the load very well but I always said that was the limit for me. Anything longer or heavier was going to be a dually.
Sent you a PM. My 2001.5 was built like a SRW 1T, but Dodge did not tag it as such. Only in 2003 did they start officially building SRW 1T's, and they had tires of a lesser capacity than my 2001.5 optional 265's.
Chris
They just don't make them like those 2nd Gen Ram/Cummins any more! The same here 01 Ram 2500 towing 05 Copper Canyon 293 FWSLS run about 2,100 pin loded and 19,000 GCVW. NO bags or Timberns, sits level, run hills all the time pull great, STOPs great goes great! The Camper Package makes all the difference, 3500 running gear and springs!
Me_Again
Cummins12V98 wrote:
Chris
Chris
45Ricochet
Me Again wrote:
dennych1 wrote:
I cant buy a new fiver and a truck my wife will be upset. I went to dumps yesterday and the weight of truck was 8k. The weight of the rear axle was 3600lbs. The sticker on the door frame said my rear axle was 6084lbs.
OK now we are getting somewhere. You have 2484 pounds available for pin weight. If you need more than that, which you most likely do. I would look for a set of GM takeoff wider wheels and install LT265/75R16E rated to 3415 pound each. That pushes you rear tires/axle to 6830 and 3230 rear capacity.
The wheels that GM uses with LT245/75R16E's are 6.5" wide and not wide enough for the 265's, which are best on 8" wide wheels. You could also get aftermarket rims.
Sounds like you have a 2007 Classic, and you should hang onto it!!!
Chris
This would be your cheapest option OP as your current setup is a no go . Your DRY pin would be in the 2600 lb range.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
therink
The bottom line is this:
1) Its your choice
2) Most any 5er with loaded pin weight exceeding 2000 lbs will overload payload on most 3/4 ton trucks when loaded with passengers and gear, hitch, etc.
3) Its your choice
This is learned through my own experience.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
Cummins12V98
Chris
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me_Again
Chris
dennis1949
I pull a 3125 Blue Ridge.. Truck does not know 5th wheel is back there. Get about 12.5 mpg if run between 60 and 63. Total weight of truck and camper is 12,300 lbs.
Dennis Carpenter
Decatur Alabama
2012 GMC 3/4 ton Z71 Diesel
2016 Forest River Blue Ridge. 3045 RL
Cummins12V98
Me Again wrote:
Cummins12V98 wrote:
dennych1 wrote:
I am thinking of
going from a 34.8 ft Everest which is 11.5k loaded to a Big Horn 3160 35.6 ft which will be 13.5 loaded. I know I will be over pin weight around 500lbs . The combined weight is within specs of truck. Just wanted to see if anyone else is carrying this weight on 2500HD diesel and how has it been.
Thanks Dennis
Dude just put some air bags and 19.5's on it and it will tow anything! Now you don't have to buy a proper truck to haul your BIGGER 5er.
As someone else said your family's safe is up to you. But in reality you effect others also.
JMHO
He already has the firestone air bags!!! Chris
GRRRR I guess I failed to lOOk again!
Well you just saved him more money. Now all he needs are 19.5's!
Me_Again
Cummins12V98 wrote:
dennych1 wrote:
I am thinking of
Thanks Dennis
JMHO
dennych1
Me_Again
Nutinelse2do wrote:
dennych1 wrote:
I am thinking of
Thanks Dennis
Seems you are coming to the forum looking for everyone to condone your actions. Nobody here is going to change your mind. If you crunch the numbers, you know if you will be overweight or not. It is a personal choice of how safe you want your family to be.
Let see, everything on his truck is the same as yours except for the rear springs and training wheels, so it is sure to fail in the first 500 miles. Tranny will go out, AAM 11.5" rear axle will fail, and the Duramax will blow its heads off.:S:S:S
Chris
Cummins12V98
dennych1 wrote:
I am thinking of
Thanks Dennis
JMHO
Cummins12V98
stro1965 wrote:
I pull a 38' KZ, dry pin weight is 1900 lbs or so, I think I am kinda pushing the limits.
"kinda" Why quote dry pin weight? Do you know what your TV's rear axle weighs fully loaded? If not you should.
You know you are in Dually territory. Possibly a newer 3500 SRW?
Nutinelse2do
dennych1 wrote:
I am thinking of
Thanks Dennis
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
Me_Again
Thanks Dennis
Over TV GVWR or RAWR. RAWR is set by the weakest link, the tires. You do not want to exceed the tire rating, period!!!
Chris
