5th Wheel a.c./heat pump and Z-Wave thermostat
gunny74
I am getting ready to replace the rooftop a.c. units (2) on my 2009 Cedar Creek Silverback G2 5th wheel with heat pumps. 1 is ducted (main) and 1 is non-ducted (bed room). I am wanting to use Z-Wave thermostats with the new heat pumps. The trailer is no longer on the road and will be stationary. The reason for the Z-Wave thermostats is because, I want to add it to my current system at the ranch (where the trailer is located) that is controlled by a 2GIG GC2 controller so I will be able to turn the units on/off while I am away or returning. Has anyone here tried this? If so, what a.c./heat pump/thermostat combination was used? I have already purchased a GoControl TBZ48 thermostat but am not against getting something different that works as well. Thanks.
0 REPLIES 0
