5th wheel pin lubricate
Fisher_Bill
So I moved from a truck camper to a fiver and while the truck was ready for a hitch I didn't have one and my buddy had an extra that's older but seems to do the job, I noticed some wear on the top of the receiver where the pin rides and it looks like it's taken about a 1/16th ridge off the top.
I mentioned this to said buddy and he said I should have a pin lubricating disc, I asked if it would be a Teflon type of washer and he said yes and sent me a link.
Wondering if I'm the only one who didn't know about this as I like to keep things maintained but relatively new to the 5er game, even though I've read several posts since changing over (4yrs or so) I must have missed any mention of the plastic washer that fits up on the pin.
Do Y'all have this on yours?
FB
2006 Chevy 3500 Dually 6.6 Duramax Diesel & Allison Transmission
2010 Northshore 28RK by Dutchmen
Our first fifth wheel!!!
37 REPLIES 37
Cummins12V98
fj12ryder wrote:
Thank you. It sure seems to tick all the boxes. The only down side we can find is that it has no slide toppers. 🙂
I had em and hated em.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fj12ryder
Howard and Peggy
"Don't Panic"
Cummins12V98
fj12ryder wrote:
Thank you. Hopefully we'll be picking up the new-to-us Momentum this Wednesday. 🙂
Nice!!!
fj12ryder
Howard and Peggy
"Don't Panic"
Cummins12V98
fj12ryder wrote:
Will the 1/4" work? I bought one and thought it was a bit thick, but don't have a trailer to check. I may exchange it for the thinner one. I was thinking the last one I had was thinner than the 1/4" one.
I used one and it worked but you will like the 1/8” much better.
fj12ryder
Howard and Peggy
"Don't Panic"
Cummins12V98
laknox wrote:
Be aware that there =are= differing thicknesses of the disks and a few hitches simply don't have the clearance for even the thin disk to fit and allow the hitch to latch properly. At least from my reading various RV fora over the past 15 years.
Lyle
The B&W is best to use a 1/8" disk than the 1/4".
laknox
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
blofgren
larry barnhart wrote:
Retired JSO wrote:
We use a disc along with white grease on the pin itself.
same for us. chevman
And for us for many years.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
Cummins12V98
ramyankee wrote:
Lately, every time I go out to storage miny disc has fallen off the pin. I go to push it back on and there is resistance so it does fit tight. Next time I am out there thinking of putting it in the truck box...
Lay it on concrete and hit all around the the edge of the center hole with a hammer. This will shrink the diameter of the hole and make a tighter fit.
ramyankee
Rick and Patti 🙂
2 Proud Christian CONSERVATIVES 🙂
2002 Chevy Silverado, 8.1, Crew, LB, 3.73, 4X4
2020 Mesa Ridge 291rls
Now living in North Idaho (formerly Northeastern California) ... but the heart is with MONTANA STATE UNIVERSITY
larry_barnhart
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
LadyRVer
Dealer suggested the Teflon disc. Used one from the very beginning. Also, lubricated the fifth-wheel hitch with white grease maybe once a year.
Sagebrush
I use an old white plastic lube plate that stays on the trailer/kingpin, I also lightly use a lithium based grease on the hitch plate for rust prevention. Any wheel bearing grease can be used though, put the grease on the king pin and it will lube the hitch jaws too.
Cummins12V98
NUFF SAID :B
