Additional fuel carrying capacity on pickup
dogvetia
I have motorhomed for years with 100 gal diesel tank. Now have 5er with Ford F-350 diesel with 20 gal tank. Miss the old duel tanks on fords of yesteryear. What have you all done to get more than 200 miles between stops? 5 gal cans in bed? Messy. Looking at 50-75 gal transfer tank in pick up bed but can’t find one short enough that tonneau cover will cover. Any ideas?
2012 F350 diesel
2018 cruiser lite 28rd
55 REPLIES 55
Bionic_Man
Lol. Who cares if the OP has 20 gallons or 26 gallons capacity? Either way, that isn’t nearly enough.
Check the Titan replacement tank of the RDS auxiliary tank. I have an RDS 60 gallon. I don’t have a tonneau cover but if I did, it would still work.
The auxiliary tank is one of my favorite things of my truck. Works great.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
way2roll
Navigator II
Navigator II
Second Chance wrote:
This is just a curiosity question... do you have a SRW shortbed? My 2012 F350 has a 37 gallon tank.
Rob
My 2020 F350 SRW has a 48 gal tank.
TXiceman
MarkTwain wrote:
TXiceman wrote:
My 2012 F350 crewcab DRW has a 37-gallon fuel tank. Apparently, the OP has a short bed SRW truck. Adding more fuel capacity to the truck will also increase the weight of the truck and decrease the capacity he can carry on in the bed.
Before adding any additional fuel capacity, weigh the truck and trailer to see how much room you have for the fuel weight.
Ken
I added a 60 gal. aux. diesel fuel tank and this did affect my milage. My 3500 Dodge truck pulls a 14K 5th wheel and it pulls with no problems after instaling the 60 gal. tank.
Did you check the gross weight of the truck and the rear axle weight after adding the 60 gallon fuel tank full of fuel and carrying the pin weight of the trailer.
One gallon of diesel fuel weighs about 7 lb. So 60 gallons will weigh about 420 lbs plus the tank. Add you loaded pin weight, cargo, etc, are you still under the rear axle GAWR?
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
MarkTwain
Ken
Rollochrome
Ken
Amen to that.
In my youth, I ran out and got the largest aux tank I could find and dropped it in the bed of a Chevy 2500 Duramax crew cab long bed. No thoughts as to what a 200 gallon tank of diesel would mean to me other than the fact that I could drive to the moon and back.
I was eager to fill it up so I did on the way home and saw what that did to the suspension and handing. Then I penciled it out and saw that 200 gallons of diesel was 1,420 pounds, not counting the weight of the tank, and that this was probably "a bit much"..
Youth... Good times...
1999 Saved By Grace Alone Thru Faith Alone! Thank You Jesus!
2019 F-350 LWB 6.7 4wd XLT-FX4-3.31 on Michelin Defender LTX M/S
2022 3850BH Cruiser South Fork on Carlisle CSL 16
TXiceman
Ken
Gener8s1
Have a look at Titan fuel tanks. Super complete kits lots of options fit under my backflip cover.
Rigdon
RDS makes a in bed auxiliary fuel tank. I got a 50 gallon one with my autoslider hitch about 800 miles on an average day pulling a fiver.
Steve & Karen
Cummins12V98 wrote:
ford truck guy wrote:
Most of the Ford SB have 26 gallon.... IF you have a lot of extra capacity, invest in a Titan - Titan Fuel Tanks
They add 55 gallons and the tank fits where the OLD tank was under the truck.
I have 32 gallons and wish I had more. My last DRW had 35 and I liked that amount. I carry a 5 in my toolbox and have used it once in the last six years. But no way would I sacrifice my big bed height tool box with a transfer tank.
If I did anything different It would be adding the 55 gallon TITAN.
My NEW truck has a 48 gallon tank... I will never tow a fiver without a long BED again.....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
dogvetia
Valhalla. I think you are correct on your v10 with 26gal. Diesel has a Def tank that the v 10 does not
2012 F350 diesel
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me-Her-the kids
Cummins12V98
dogvetia wrote:
Jerry. Believe it or not it is 20 when empty. Makes no sense to me and I been a Ford guy since 1974!!!!
Just because the gauge says empty does NOT mean it's empty. What does your owners manual say?
BarryG20
Unsure what truck you have but take a look at Titan fuel tanks. They may offer a midship replacement tank. Based on some info in your post and some assumptions ford, 350, short bed, diesel 2017-2022 they offer a 55 gallon tank that takes the place of your existing fuel tank. No bed space lost or additional plumbing. I have had them in my last couple trucks and worth every penny as far as I am concerned. The new truck I have on order comes with a 50 gallon tank so wont put one it.
I have used Titan but transfer flow, S&B, or Aero tanks may make them as well
https://titanfueltanks.com/products/xxl-replacement-tanks?find=2019-ford-f350-4678&sid=NTAFkrcZnz
2016 Jayco 28.5 RLTS
ferndaleflyer
I don't understand the different capacities. I have had 3 F-350 diesels and all of them held 40gal. Even a C class I had years ago had a 40gal tank. But I put an extra tank in the bed of all of them, not the C. Those real old ones did have 2 tanks but still around 40 gal.
