Antifreeze leaked and the floor is damaged
grandmajj
We recently just purchased a Sportsmaster Classic 1996 5th Wheel. It is in awesome shape with one exception. The trap under the sink (I think that is what my husband said) wasn't tight and the anti-freeze leaked under the sink, tub, toilet etc. We are trying to figure out how best to repair this. My husband and sons are all "born handymen".
5 REPLIES 5
stickdog
Are you just talking about discolored flooring or subfloor damage?
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
colliehauler
Can't imagine enough antifreeze could leak to do damage. Agree with others it had to have a prior water leak to do damage.
I'm wondering if the prior owner forgot to winterize and poured antifreeze in after the damage was done.
laknox
If there are =any= soft spots in the floor, then everything needs to come out, down to bare wood. Replace the rotten wood, then reinstall flooring and fixtures.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
sch911
That amount of antifreeze shouldn't have caused any significant damage to the floor, unless that drain has been leaking a very long time. Sounds like you might have a leak somewhere else if the floor is really damaged.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
azrving
