Auto transfer switch replace
12th_Man_Fan
Trying to replace the auto transfer switch on my RV since I don't have a generator and the switch is constantly buzzing loud enough to hear inside if nothing else is running.
I would like a box of similar size with internal connectors to keep from using wire nuts. I have been to Home Depot and Lowe's but can't find what I am looking for.
Anyone have any suggestions? The box is 7" X 9.5". Thanks in advance for your help.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
6 REPLIES 6
Cameo_Phil
Go to an electrical supply house.
2002 Carriage Cameo F35CKB
2005 Chevy 3500 LT, CCLB 6.6L Diesel 4X4
12th_Man_Fan
pianotuna wrote:
Why not just eliminate the transfer switch?
That is what I am trying to do but have to splice the wires and prefer to use a box of some kind.
2015 DRV Tradition
pianotuna
Nomad III
Nomad III
Regards, Don
john_bet
I suggest you gut your current box and get some block connectors from an electrical supply house and you will be set. Home Depot or Lowe's might even have the blocks, but I have never looked. I know an electrial hose will have them.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
time2roll
I think a disconnect box might work for what you need.
You just want to remove the box and connect wires direct right?
http://www.homedepot.com/p/GE-60-Amp-240-Volt-Non-Fuse-Metallic-AC-Disconnect-TFN60RCP/100674085
Alternative would just pull new wire and no box at all. Just leave a loop if you decide to add a TS in the future.
Also check your TS connections. Main cord should connect to the normally closed position and the coil not powered at all.
garyemunson
The buzzing comes from the relay not 'sealing up'. When it energizes, the two metal parts must make a good, solid contact. Dirt between them will make them buzz. They buzz long enough, the surfaces get 'roughed up' making it buzz worse. A little cleaning, and if necessary, putting a piece of emery cloth on a flat surface and sanding the pole pieces flat will do the trick.
