Jun-20-2018 04:03 PM
Jun-26-2018 01:22 PM
Jun-26-2018 12:32 PM
aviator41 wrote:
I called B&W directly to find out what they recommend and why. Their Recommendation is to cut the bed rug to ensure the tightest possible fit between the hitch and the bed/turnover ball frame. The idea is that they don't want any flex points that could allow the bolt you torque to 60lbs to work loose at all. They don't want to risk the pin having any "slack" at all that could allow to beat itself to death in the turnover ball socket.
Cut the bed mat. if you want, keep the pieces and put them in place when you're not running with the hitch installed. For me, that was too much work.
Jun-26-2018 12:01 PM
Jun-20-2018 05:39 PM
Durb wrote:
You can use an 18k Patriot with standard bed rails. I cut out rectangles in my BedRug to fit tightly around the rails. This works particularly well with the thick BedRug as stuff like lumber just slides over the rails when loading. Almost like a flat floor; I said almost.
Congratulations on the new trailer.
Jun-20-2018 05:30 PM
Jun-20-2018 04:45 PM
AZ T&T wrote:
I initially installed mine on top of a heavy rubber bed mat. Ended up cutting a hole in it. There was just too much movement after the mat started flattening out.
Jun-20-2018 04:44 PM
