Mar-28-2015 08:01 PM
Apr-07-2015 02:40 PM
Apr-07-2015 09:14 AM
gkainz wrote:
"Lord, I apologize for that right there..."
Larry the Cable guy. 🙂
Apr-06-2015 08:02 PM
Apr-06-2015 06:15 PM
Apr-06-2015 02:16 PM
gkainz wrote:
Install laser levels in the bed of the TV, attached to the kingpin on the 5er and also alongside the TV roughly aligned with the 5er kingpin.
GoPro video cameras attached to TV bed with a clear view of the jaws of the hitch, and attached to 5er kingpin, pointing down onto the hitch.
Proximity sensors attached to kingpin and 5er hitch, with a beep frequency that increases as distance decreases, ending in a steady tone with the kingpin contacts the jaws of the 5er hitch.
Activate lasers, ensuring that the laser light paints the hitch and kinpin.
Enable cameras.
Enter TV cab and ensure all cameras are transmitting images to the in-cab laptop.
Exit TV and adjust cameras. Repeat until satisfied.
Begin backing slowly toward 5er, while watching the laser lights, the in-cab laptop and listening to the proximity beep.
Exit TV 4 times to check kingpin height.
Continue backing toward TV.
Exit TV to remove neighbor's cat that you backed over.
Return to TV and continue to back towards 5er.
Neighbor's dog just knocked over the laser levels. Shut down, exit TV, reset all lasers, cameras and start over.
OR .......
just eyeball the darn thing "close enough", back up - get out and eyeball as necessary, and "hitch up!" ... it gets easier with practice!
Apr-06-2015 10:04 AM
Enable cameras.
OR .......
Apr-06-2015 09:45 AM
Apr-05-2015 11:20 PM
Old-Biscuit wrote:
If I get lined up good enough to clear my 5vr tailgate then it will hit the mark and hitch up.
Love that 4 way pivot head and "V" shaped tailgate.
I only get out of truck once and that is to verify hitching, hook up cord/brake cable and finish up 5vr. Then it's crank up Willie 'ON THE RAD AGAIN' and hit it.
Apr-05-2015 10:44 PM
Apr-05-2015 10:23 PM
rskeans wrote:What about wheel chocks? I have been taught by the members of this forum that the last thing you do is remove the chocks. It is OK to use the electric brakes with the chocks choks but to use the brake alone is risking an accident roll back or roll forward
When I was using a standard (non Andersen) 5th wheel hitch, I always used the manual trailer brakes to lock the 5ver wheels before I backed into the King Pin. It prevented movement of the 5ver if I hit it too hard.
Apr-05-2015 08:28 PM
Apr-05-2015 08:20 PM
Apr-05-2015 07:15 PM
Apr-05-2015 07:13 PM
