Batteries, dimming lights, etc.
melissajean0
Okay, so I know that RV's should run without a battery when they're plugged in. It seems like every time we either move the 5th wheel or if it storms and the power surges (or goes out and runs off the battery), or if it flickers off because of a storm then back on, the battery always goes dead. Every single time; even though we're plugged in to a 50 amp outside. Today we swapped batteries, turned the air on, a few hours later the new battery was dead. So we went and bought a batter charger. Put the charger on the battery, waited an hour (didn't remove battery from charge), still no 12v lights, ac/heat thermostat not working, and fridge not working. We have a 2008 Forest River Sandpiper, model 345RET. We have flipped the breakers, checked the fuses, and nothing seems to be working. Does anyone have any idea on what could possibly be causing this?
Thanks in advance 🙂
Husband: Jeremy; 1 Springer Spaniel; 1 Toy Schnauzer
F350 SD 4x4
Ford Edge
AL, AZ, AR, CO, FL, GA, IL, KY, LA, MS, MO, NM, TN, TX, UT, WY, OK, KS
London, UK, Ipswich, UK.
49 REPLIES 49
FrankShore
Here is a basic primer:
Converter Troubleshooting
They all work the same, so don't be put off that these folks have a small vintage trailer!
More Info:
Troubleshooting
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk båt - Dette må jeg se!
melissajean0
towhead wrote:
Have you checked for proper converter output?
How do you check that?
F350 SD 4x4
Ford Edge
melissajean0
FrankShore wrote:
Sounds like you've done irreparable harm to your battery. I'd skip the charger and buy a new battery! That or your converter is blown!
It can't be the battery because the one we put in it today was new. 😕 How can you tell if it's the converter? Everything else in here works great. Plug in lamps work fine, fans, plug in heaters, fans, air conditioner in the bedroom (isn't on the same system as the ac in the living room that works w/ a thermostat), tv works fine. Everything except wall lights, fridge, and ac that uses the thermostat.
F350 SD 4x4
Ford Edge
towhead
Dave
2005 GMC Duramax 4x4 crew cab
2005 Cruiser CF28RL
FrankShore
2014 F-250
