Body shop repair
army_guy1
Looking for a good body shop to repair a slide out floor. We are currently in Arkansas.
Rick & Jana
Full timing since Oct 2005 - retired US Army Dec 2009
2018 Arctic Fox 27-5L
2014 RAM 3500 Big Horn
7 REPLIES 7
fj12ryder
It really depends on which floor is bad. A bedroom slide might not have to be removed. I redid the floor in our bedroom slide without removing the slide. It's a bit inconvenient, but definitely do-able.
Howard and Peggy
"Don't Panic"
Dandy_Dan
FYI to do it right in replacing the floor, slide will need to be removed and tipped on the floor so they can get to the that hold it in place. Not a real quick fix. I know-just had 3 done due to bad seals.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
Dandy_Dan
FYI to do it right in replacing the floor, slide will need to be removed and tipped on the floor so they can get to the that hold it in place. Not a real quick fix. (don't ask how I know-just had 3 done due to bad seals.
dan218b@tds.net
alexleblanc
i'm sure there's a good RV repair place in your area, not a dealer but and independent, that's where I've had my best luck over the years.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
JW_of_Opechee_S
Check out rvservicereviews.com
Have Fiver will travel with little or no notice at all. I do need to stop at rest areas now and then:)
Goostoff
body shops might not have wood working tools.
1993 Chevy C3500
2005 Cedar Creek 34RLTS
fj12ryder
I think you're looking for an RV repair shop. I don't think a body shop, which is a shop that works on car bodies, is going to be what you need.
Howard and Peggy
"Don't Panic"
