Can you jump your 5’er with your truck?
Mondooker
Hi guys, If I’ve seen this before I don’t remember it. Can you jump your 5’er batteries from the truck?
32 REPLIES 32
Veebyes
If the trailer battery bank is low, for whatever reason, plug into the truck as per usual & run the truck as fast idle for a bit before trying heavy draw things like slides.
2007 Alpenlite 34RLR
2oldman
Bionic Man wrote:
If you are concerned about slides and jacks with dead trailer batteries you could plug trailer umbilical cord into the truck (with truck running) and have enough power to use the jacks and pull in the slides.
I guess so, but that doesn't jibe with the comment above about how cables will get hot. Hot comes from a lot of amps. Umbilicals don't carry a lot of amps.
Mondooker
I DID NOT KNOW THAT!
Bionic_Man
Why are you wanting to “jump” the trailer? If you are concerned about slides and jacks with dead trailer batteries you could plug trailer umbilical cord into the truck (with truck running) and have enough power to use the jacks and pull in the slides.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
time2roll
Mondooker wrote:
My unit has two 6 volt batteries, four 6 volt batteries actually.
Together it is one big 12v battery. Connect on the right terminals and all will work fine.
jdc1
2oldman wrote:
jdc1 wrote:
To maybe pull in a slide or raise the jacks? Why not? But, your cables are going to get REAL hot.
Hot? Running jacks?
That's 25 foot of cable that'll be needed. You should see how hot my in bed transfer pump cables would get....and they were only 12' long.
6X2=12volt
bob213
It takes two 6v batteries wired in series to make a 12v. If you were to jump them you need to connect one cable to each battery NOT both cables to one.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
Mondooker
My unit has two 6 volt batteries, four 6 volt batteries actually. Hopefully the solar will keep the batteries up? But great to know the truck batteries could be used if necessary.
Thanks guys
Roger10378
Very few if any 5er's use 6 volts. They may have 2 6 volt batteries wire in series to give 12 volts but nothing in them runs on 6 volts. you would need to jump 12 volt to 12 volt.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Mondooker
I wasn’t sure you could jump a 6 volt batterie with a 12 volt battery?
2oldman
Hot? Running jacks?
jdc1
MNRon
Why not?
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
way2roll
Navigator II
Navigator II
Not sure what you mean by jump. Do you mean can you link your truck batts to your FW to charge them - like with jumper cables? Don't most do this when you plug in the tow power cable? But yes, using cables would be the same as linking them together, just temporarily.
Jeff - 2023 FR Sunseeker 2400B MBS
pianotuna
Nomad III
Nomad III
Yes.
Regards, Don
