Changing standard ac to whisper air?
hoodidean
Researching....can a standard ac be replaced with a whisper or quiet air. We have a 2015 Heritage Glen 5th and would like to switch if possible. It is ducted but still very loud.
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post in the RV Forum which corresponds to the subject of your topic. Thank-you!"
3 REPLIES 3
1492
Moderator
Moderator
Moved from FORUM POSTING HELP AND SUPPORT
mike-s
Wrong forum.
azdryheat
It can be done but might be quite expensive. Go look at the higher end RV's with fully ducted air to see how they're layed out. Fully ducted is where nothing of the a/c unit can be seen in the ceiling. I won't have another RV that isn't fully ducted. Mine has two return ducts on the sides of the ceiling near the walls. Others have circular ducts opposite the exhaust ducts down the middle of the RV. You might just want to upgrade your RV to a better unit.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
