Drawer slide
jacquesp
I need to extract my drawer from the slide so that I can re-secure the drawer frame, however cannot figure out how to separate drawer from slide mechanism.
The unit is a 2011 Cougar RKS 278.
Any insights would be appreciated.
Thanks.
5 REPLIES 5
jacquesp
Thank you all for your replies. therink described the solution I needed to remove the drawer- very special thank you. At least I can continue on the trip back home without this drawer flopping around for 800 Kms.
I assume the drawer will slide back in past the black plastic locks.
Dick_B
Open the drawer until it stops then lift up and out. Works for me.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
tkcas01
My rig has two types of drawer glides. No different than home cabinet glides.
This one with the little black tab you kinda have to know is there, and the other type has a catch on top of the glide that is pretty hard to miss.
Roaming Full Timer
korbe
I would open the drawer until it stops, and take a look at one slide and see what's going on. Many different types of slides. See what stops it
therink
If you are referring to an interior drawer, my drawers (Keystone) all have black plastic tabs on both sides towards front of guide rails. Push down on one tab with thumb nail and pull up on other. Drawer should pull right out.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
