Electrical Issues - connected to shore power or generator
goodwin297
We have a 2015 Bay Hill 340RK. We have a propane Onan generator. We used it last night when we stayed at a truck stop. The outlets on the GFI (near kitchen and bathroom sinks and the microwave wouldn't work. Got to the RV park and plugged in, those outlets and microwave work but now the other side and the bedroom outlets don't work. The generator was installed by manufacturer and dealer.
Any advice appreciated until we can get in touch with the dealer on Monday.
Thanks,
Trudi
Full-Time RVers since 6/16/2012
Our home:2015 Evergreen Bay Hill 340RK
2014 Ram 2500 Laramie 6.7 Cummins Diesel Crew Cab
Doggies - Molli, Indi and Louie
3 REPLIES 3
goodwin297
Thanks for the advice. Hubby did find the breaker on the generator so that solved the issue of 1/2 of rig not working when generator running. Still had the issue with the other 1/2 not working on shore power. Had RV repair guy out and it is the transfer switch hanging up. All good now.
time2roll
Did they work before? Have you turned all breakers off firmly to reset and then back on? Also check for breakers on the generator.
Almost sounds like the wiring is wrong in the transfer switch.
Watch your battery voltage is not dropping.
Golden_HVAC
Check all of your GFI's and make sure that every one is set. If any are tripped, then the outlets that are downstream of that GFI will not have any power.
Good luck!
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
