Found these specs:
Slides 0
Length 29 ft 5 in
Ext Width 8 ft
Ext Height 10 ft 5 in
Exterior Color White
Hitch Weight 710 lbs
Gross Weight 8000 lbs
Dry Weight 5005 lbs
Cargo Weight 3400 lbs
Fresh Water Capacity 100 gals
Grey Water Capacity 35 gals
Says you have a cargo weight of 3400 lbs.
Even if you top off with water (100 gallons) that's about 900 lbs.
So...I'm confused where you are getting only 800 lbs of cargo capacity remaining - even if you load up you trailer with the normal gear, etc.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
