Factory Tour's
Lostincanada
We have been hunting for about a year now for a new fifth wheel. Early on one dealer said to us “all manufactures’ use the same products and build them the same way.” This struck a nerve with us and wanted to know if this was true. Besides we were at wits end listening to dealers pointing to brochures for answers while having a perplexed look of confusion on their faces as we asked about fundamentals like how was the underbelly heated exactly. I have to admit when a couple manufactures reps looked the same way we got scared and decided to take matters in our own hands by going down and visiting plants in Indiana.
So with lists of concerns in hand we traveled and set up 4 tours. We had narrowed down three units we were very interested in and one unit we heard was a don’t buy. This we thought would allow us to really compare units. One tour was done after plant working hours, two were during plant working hours (Grand Design was one of these) and one just at end of shift. During working hours gave us the best insight on how coaches were made in that given plant. Basically speaking yes all plants pretty much use the same “stuff” to build units, it’s all done pretty much the same way but there are differences.
Grand Design uses the same frames as others but have added extra support and braces to the unit at stress points giving it a more robust frame. Due to some of our research and personal experience we already were looking at those exact points of stress in units because they have been known to fail. We focused on the Reflection during the tour. Seeing a proactive approach with Grand Design on not even the top of the line unit pretty much sold us right there. I think it should be a selling point in future literature.
On the bedroom portion of the frame Grand Design uses actual L brackets welded to the frame which will hold the side walls, other manufactures use thin metal rails tacked to the frames at varying points and we saw this rail bent all out of shape way before a wall was placed on it. We feel Grand Design did it better.
We really liked Grand Design’s choice in their whole approach to HVAC system, from no in floor ducts to trap dirt while camping to actual ducting rather than the cheap dryer venting like product common in other units.
We liked the care in which the underbelly was dealt with. They took their time wrapping all the tanks and thought about using the coach in colder temps. Water lines are protected, heat ducts are in the right places and they used good products. One plant appeared to use trashed reflective material that didn’t even fit right and had chunks ripped out of it.
Speaking of reflective materials, Grand Designed used way more of it then some others, the nose cap has it as part of the insulation, I have to add also had the most framing under the nose cap (one unit had none!). Reflective material was part of the ceiling, up along the back wall and slide floors.
Other items that got our attention, carpet delete, great option for us with dogs. Not having frameless windows a plus for us who like to have a breeze. The pantry! I can’t say enough about the pantry! Love the quirky glass door and pantry written on it, adds a lot of whimsy to the coach. Outside doors open correctly under the slides to reduce hunched back and head cracking. We liked how services like water and drain tanks were tested along the line. Actual wood supports were included for areas of heavy stress like as a backer for the ladder (I think Grand Design was the only one).
I would like to suggest Grand Design offer heated tanks on the Reflection line.
Another thought would be incorporating something many RV owners already mod, the screen door. Many of us add lexan panels to the door. This allows us extra light in the coach while running the a/c or heat. Having it removable allows extra breezes on days like today. It also saves the screen from dogs and little kids.
As a company I think their plant was one of the cleanest, floors were cleaned up, things were not piled all over the place, it was very well lite etc, even their coaches were fairly clean during the building process. One plant we visited looked like a disaster zone and the coaches were filled with construction debris, trash, tools, scrap, nails and screws just waiting to cause problems. The floors looked like they haven’t been cleaned for a month and it was so messy it looked like a hazard for the staff. For us how the plant looked showed care and concern for the construction process at Grand Design.
Another plant we visited actually laid material on all the vinyl floors and on counter tops to protect them, we thought that was a great idea maybe something Grand Design can look at.
Our guide was more than happy to show us any part of the process took his time explaining things and didn’t rush us at all. We also got to meet all the owners and were pleasantly surprised they took time out not just to say hello but talked to us and seemed honestly interested in what we had to say, good and bad. The open welcoming feeling we got during the whole visit really added to our already made up minds this was a company we really wanted to buy from. In fact we told the reps doing all four of our tours the same thing, we are doing this figure out which unit to buy and your unit is on our list. Grand Design is the only company to follow up with us.
Lost
2015 Grand Design 337RLS
2012 Ram 2500 CTD
Winter camping tips and tricks!
15 REPLIES 15
Randu
Glad you did the proper "Homework and research". Amazing at the details that you see during assembly. Things like crimped duct work and spaghetti wiring compared to how things should be done or how I would do them. Please add the other plants that you toured. Don't need the in depth good/bad but interested in knowing where you went for perspective of what was being compared.
I toured Newmar, Travel Supreme, Carriage, and DRV back in 2008. Seen a few things at 2 of the 4 that partially explains why 2 are now gone and 1 stopped building 5th wheels. Grand Design really caught my eye last spring at the Detroit RV show for construction and value. I have been watching their website and seen that they delivered their 1000th unit a few weeks back. Not bad for a company that produced unit # 1 in November 2012. Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison.
2017 Jayco North Point 381DLQS
Previous: 2000 Travel Supreme
2005 Newmar Kountry Star
2008 Mobile Suites 36TK3
