โMay-25-2018 02:41 PM
โMay-28-2018 06:16 AM
larry barnhart wrote:
My thoughts about china made tires are this. Bought a new 2018 car with China tires and traded them in before 500 miles.
chevman
โMay-27-2018 10:51 PM
CALandLIN wrote:Colbee55 wrote:
What kind of tires for the 5th wheel seem to hold up the best?
Looks to me like youโre refitting an older trailer with new tires. A lot has happened in the tire industry since your trailer was fitted with itโs original tire & wheel assemblies. Probably the best thing to do is a complete assembly change for all wheel positions.
Any of the ST225/75R15 LRE tires will provide the load capacity you seek. There are numerous manufacturers to chose from with GY being the only USA manufacturer and they will be the most expensive.
However, there is a new all steel 15โ trailer tire available. Greenball is providing them and their brand name is Tow Master. They are ST225/75R15 LRF.
Click Here!
โMay-27-2018 07:08 PM
โMay-27-2018 08:17 AM
Cummins12V98 wrote:Mine calls for 50 psi and I run them at 65. No center wear, stops just fine, rides better than ever.
Over inflation will cause center tire wear, less stopping ability and worse ride.
โMay-27-2018 07:35 AM
โMay-27-2018 06:39 AM
time2roll wrote:
80 psi for max load rating. Why not 80 psi? Put them on and air them up. I bet they ride better than ever.
โMay-27-2018 04:39 AM
โMay-26-2018 10:52 PM
xtech wrote:
Hello, I am a fellow Albertan. Just put my third set of Road Rider ST tires on. Have had no problem and tow many miles, down to Arizona in winter and around Canada summer. Road Riders are from China but are recommended over even the new made in USA goodyear. Go to fountain Tire, they handle them. They come in your size in Load Range D or E. I just put on 4 E range, $119.00 Canadian each. D range good for approx. 2500 lbs each and E for 2800 each so D would work for you. Talk to Fountain Tire they sell lots and recommend them.
โMay-26-2018 09:42 PM
โMay-26-2018 07:17 PM
โMay-26-2018 06:48 PM
โMay-26-2018 06:00 PM
time2roll wrote:Colbee55 wrote:I recommend Goodyear Endurance inflated to 80 psi. New design and made in USA.
27 1/2 ft Travelair, 8000 lbs empty.
We have been pulling with an '02 Ford 350, short box, crew cab.
Have been running on P22575r15 load range D but have 2 blow outs in the last 2 times I have been out.
I am looking for a good tire not from China if possible.
โMay-26-2018 03:36 PM
โMay-26-2018 03:32 PM
