Fresh Water Tank Filling Up
hermannm
Hi I have an issue with my fresh water tank. When I have the RV on "flow" the tank still slowly fills with water.
3 REPLIES 3
hermannm
I usually use the water pump and tank as well but leave the city water on so i just have to move the switch on the rig to fill the tank again. I have replaced the o-rings on the valve to switch between fill and flow.
Old-Biscuit
Either pump internal check valve is leaking allowing city water to backflow thru pump
OR
'Fill' valve is leaking thru
Fill up fresh water tank.....turn off city water source and use pump
Flow thru pump may clear check valve (diaphragm) of any scale/debris
After using tank of water with pump....swap back to city water if you wish.
I always use pump/tank.
Flooded rig one night while sleeping on city water and fitting broke...$6000
Since then.....pump/tank and just fill tank as needed
Easy to turn pump off when sleeping, going outside, leaving cg etc.
Allworth
Probably a bad check valve at the pump.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
