Sep-27-2021 11:20 AM
Oct-04-2021 08:52 AM
mhardin wrote:
Insects like to crawl up lines and build nests that cause blockages. Mud daubers are especially bad about it around here.
Sep-28-2021 06:49 AM
M.R.E. wrote:
I wasn't blowing air up the low point drains for hot and cold water. It was the fresh water drain which also looks like a low point drain but is the fresh water drain. I pushed up the drain a coat hanger wire and felt a blockage and after going up and down for awhile it went up and drained the tank. I filled it and drained it and everything is fine. There must be some debris that blocked it.
Sep-28-2021 06:42 AM
Sep-28-2021 05:43 AM
M.R.E. wrote:
I only have gray and black water drains. Other low point drains are for hot and cold water drains.
Sep-28-2021 05:36 AM
Sep-27-2021 07:38 PM
MFL wrote:Cummins12V98 wrote:
Could be an internally leaking water pump.
Yup, that happens, can put water in tank, but OP states that he added water to tank, but nothing comes out drain?
Something is amiss, curious to hear outcome!
Jerry
Sep-27-2021 01:25 PM
Sep-27-2021 12:40 PM
MFL wrote:
You say "fresh water tank never used", but yet a little water comes out when winterizing??
Sounds silly, but are you sure you are opening the fresh water tank drain, or maybe the low point drain?
Jerry
Sep-27-2021 12:28 PM
Sep-27-2021 11:48 AM
Sep-27-2021 11:34 AM
