Fuse locations 2004 f350, brakes not working
klr650goldwing
The brakes do NOT work on our 5er. The repair shop suggested I check the fuse before we schedule an appointment. He thought it would be under the hood. I don't see a fuse panel under the hood. I do see a small black box with 4 relays in it, but not fuse panel. Question 1: is there a fuse for the trailer brakes only? Question 2. Where would that fuse be located? Question 3. Is there anything else that would cause the brakes to not work at all?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
4 REPLIES 4
theoldwizard1
Assuming you have the FACTORY trailer tow wiring, see page 194-199 of the 2004 F350 Owner's Manual. Position 101 is correct.
From page 194,
Passenger compartment fuse panel / power distribution box
The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the panel cover to access the fuses. To remove the fuse panel cover, turn the panel fasteners counterclockwise.
enblethen
What type of brake controller do you have?
Does the brake controller light up when operated manually?
Some after-market have an in-line fuse. Trace the wire from controller to truck connection.
Check the wire from the brake light switch to the controller.
Integrated brake controller should have fuse in trucks fuse block. 2004 maybe the one left of steering column under the dash.
Do not confuse a 30 amp trailer power feed with brake.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MFL
Nomad II
Nomad II
Should be a fuse box diagram in your owners manual, showing each fuse and function.
I would use a multi-meter to test, starting at truck connection. A simple 12V light tester should show current, while helper is applying brakes. If good, I'd move on to junction box, near pin box, that cord goes into, to check for brake wire power.
Jerry
justaboutretire
There is a 30 amp fuse listed for your truck. Should be position 101 and it is a large fuse not one of the Mini fuses. Look under the hood most likely on the drivers side for the power distribution fuse box. It is rather long. A bad ground could possibly cause the brakes not to work. Do the running lights work on the trailer? Check the brake wiring at or on the axles. Possible the wire insulation may have worn away and bare wire to metal grounding.
Bill & Diane
3 Boys, 1 dog
1DIL, 3 Granddaughters
2002 Excursion Limited\w 7.3 PSD
2003 Citation 33M TT
