Fuzion Black tank leak
danr1707
Hi Guys,
Have a leak in my black tank. Luckily, I discovered it after I had dumped my tanks, so I'm not using the toilet.
I'm going to replace the tank. Problem is I don't know which one to order.
According to my dealer, Keystone parts website shows 5 different possible tanks. I have a 43 gallon tank according to the Fuzion brochure from 2010.
24 x 63 x 7 (right side drain)
24 x 63 x 8 (left side drain)
28 x 59 x 8 (End Drain)
26 3/4 x 54 3/4 x 7 1/2 (Left Hand End Drain)
24 x 63 x 8 (Right, CF Only)
Without physically measuring it, does anyone know how I can tell which one I have?
Thanks, Dan
2018 Jayco Eagle HT 29.5FBDS
2017 F-350 6.7 4x4 CC LB SRW Lariat
2 Parakeets
Senior Member only because I've asked over 200 stupid questions!
6 REPLIES 6
Y-Guy
Moderator
Moderator
danr1707 wrote:
Dealer is going to do the job. They did contact Keystone and there are no records of which tanks are in which units.
Yikes, how sad is that they have no idea of what parts they slap in an RV. Then again having owned a couple Keystone products I'm not totally surprised.
Glad you got the part number and getting it taken care of.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
danr1707
Y-Guy wrote:
Dan, without dropping it I fear it's just a wild guess. It does seem like the dealer should be able to contact Keystone to find out which one was installed in that model year. Is the dealer being lazy? If you are doing it yourself that might be the case.
I'm traveling now, I wanted to have my dealer order the tank before I got home, so it would be waiting there.
2 Parakeets
danr1707
OK, I was able to get the number off of the tank. Dealer has it ordered.
2 Parakeets
danr1707
valhalla360 wrote:
It shouldn't take more than 5min under the rig to measure it.
Don't have us guess. Pull out the tape measure.
Thanks for your suggestion, however, it's not that simple
2 Parakeets
valhalla360
Nomad III
Nomad III
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Y-Guy
Moderator
Moderator
