Garage flooring
cutty72
Have a question for you guys.
The vinyl flooring in my garage area is ripped/cracked and coming up. I'm planning on pulling it out and was wondering if I could just put down the DIY bedliner product on the floor and ramp door? That would give me a better guard against water/gas/oil as well as mud, plus a little more grip for getting things in and out.
What's your thoughts/experiences?
5 REPLIES 5
cutty72
64thunderbolt wrote:
Remember, anything with a texture will be difficult to clean.
Not too worried about it being perfectly clean, it's the garage floor.
Thanks on the other suggestions, I'll look into them as well.
jetboater454
Mine came factory with the spray in bedliner type flooring. A little hard to sweep,but with the vacuum cleaner it's no problem keeping clean.
2011 Toyota Tundra DC Long Bed
2001 Harley Dyna Lowrider
64thunderbolt
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
Y-Guy
Moderator
Moderator
Check with your local flooring store, ask about the Coin-Grip flooring.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
tkcas01
Another option might be G-Floor.
Roaming Full Timer
