Inside 12V lights blink on one side when water pump is run
techminer
When the water pump comes on in my fiver, the inside 12 volt lights blink as the pump cycles. Anyone have a possible solution to this issue?
6 REPLIES 6
larry_barnhart
I guess it is still one of the batteries being low or a bad cell. But if you know the batteries are good for sure maybe not.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Old-Biscuit
If you are connected to shore power then you need to check the converter DC output AND the battery state of charge
Dimming lights when another DC component is being used usually means battery voltage is down.
Only some of the lights blink...then water pump and that string of lights seem to be feed from same circuit.
Water pump should be on it's OWN DC circuit with separate fuse.
techminer
Connected to shore power, batteries ok. ??? Only the interior lights on the road side blink. Street side lights ok.
Old-Biscuit
X2 on the low batteries.
I take it you are not connected to shore power so your converter is not in service.
How are you maintaining charge on batteries?
2oldman
Sounds like the classic symptoms of low batteries.
1492
Moderator
Moderator
Moved from Forum Technical Support
