โNov-23-2015 11:39 AM
โNov-28-2015 01:44 PM
โNov-24-2015 04:52 PM
โNov-24-2015 11:26 AM
d-mac1 wrote:okan-star wrote:
I had the same , or similar thing on my Hitchhiker water tank .
Tank vent was at the side on top , and would be water logged , venting no air as tank would continue to blow up like a balloon with a huge air pocket in the top center
It cracked at an inside corner at the top , because of the stress.
I pulled it out and had a shop weld the cracks and put a gusset on it
Also had them weld in a new fitting in the top center , which I tee`d into the existing vent line
I don't fill the tank until the vent line pucks water , I stop when the panel says its full , all good now
Sounds like same thing!! Yes...vent is near top but on side. Also, the routing of my vent line goes up and down along the bottom of my trailer to an opening up by the rest of my connections on the side of my trailer. When I got the trailer, the vent line hung underneath and it would siphon. Took it back and dealer 'fixed' to like this.
How did they weld the cracks and what is the gusset? Is the latter essentially a strap around it to keep it from expanding?
Who did you find to do the work? I dunno if there is a shop in the Denver area that would do it, but I like it better than buying a new tank for around $500. Of course, my dealer wants hundreds just to install and remove so I'm hoping to fix it myself and will prolly hafta stop the fill like you do....i.e. before its really full.
I can hear my vent line go under water when filling...a vent at the top should be the only way to do things on a tank, but perhaps there is no space. I won't know until I really get in there. My tank is a 100 gallon flat rectangle the full width of my trailer between the frame. Why did you leave the side vent line on?
โNov-24-2015 06:06 AM
TrickyRicky wrote:
Where are you getting your tank from? If from the manufacturer of your trailer it may come with the fittings already installed. On the few I have worked on they have been already installed.
โNov-24-2015 04:27 AM
โNov-23-2015 08:57 PM
โNov-23-2015 04:17 PM
โNov-23-2015 04:01 PM
d-mac1 wrote:
I am contemplating installing a new fresh water tank in my trailer. Its a long story, but the short version is I've apparently got a couple hairline cracks in mine as a result of how the vent is installed (it goes under water and the tank expands until the pressure is enough to blow water out the vent line)...plus possibly some freezing at the pump line connection last winter.
If I can find a tank that fits, which seems like I should be able to, can anyone tell me how to drill in the fittings for the fresh water fill, vent and pump line connections? From what I've been told, manufacturers don't use glue, but they spin em in and allow the heat generated to seal them. I dunno if thats right or not.
Thanks.
2008 Newmar Torry Pine
2013 F350 Platinum, Pull Rite Superglide
A Cocker Spaniel "Tucker" a Cavalier King Charles "Lilly
and us Elaine & Rick
