Installing sliding trays
cKarlGo
I recently bought a set of the rails to make sliding trays for my 2012 Montana 3402. Looking at the instructions and at the estimated placement of the black and grey tanks for the bathroom and bedroom, I'm not entirely certain that I can install (or have these installed) on my unit.
Has anyone else done this on a 3402 or similar unit? Any issues/cautions/suggestions?
Thanks!
k.
2014 Itasca Suncruiser 38Q
2014 Honda CR-V
2007 Black Lab/Pitt Bull mix named Harley
6 REPLIES 6
cKarlGo
Allworth wrote:
We had one in a previous trailer and I found it to be a waste. You not only loose square footage, you loose the height between the old floor and the top of the slide. I may have been influenced by the fact that that particular trailer had pass-through storage doors, but I wouldn't bother with a slide again.
I'd have to measure again, but I think that the clearance for the lip of the compartment and the thickness of the plywood was 2 3/4", so I'm not losing much there either. The Montanas have doors that are pretty close to the size of the basement itself, which cuts down on the wasted space that you had to deal with.
I'll have to do the measurements again and I'll post exact numbers on the dead space I expect.
k.
2014 Honda CR-V
Allworth
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
fj12ryder
From the measurements and calculations it doesn't seem like you'll lose much space, but we had the slide and I almost took it out many times because of the amount of room it cost us. We didn't like it at all.
Howard and Peggy
"Don't Panic"
cKarlGo
brirene wrote:
Only thing I've seen is that a lot of folks end up not being happy with them because of the floor space they take up. I had always thought they would be a nice mod, but after I saw that, now I'm not so sure. If you decide to do it, please post your thoughts about them.
Will do.
At this point, I think I'm going to eat the cost of installation and take the unit to Camping World to have it done. There's no way to tell where the tanks begin and end without yanking off the bottom of the unit and I'm just not willing to take that on a a project. Since I can't tell where the tanks are, there's no way to know where it's safe to drill. CW should have a pretty good idea of how to install these.
As to the floorspace issue, I'm not totally clear on the problem. Based on my math, the loss of space for my unit is about 1 sq/ft. Considering how much easier they will make it to pack the basement, I decided I could sacrifice that much.
That being said, I think much has to do with the shape and positioning of the basement doors. For my unit, the slide rails can go almost flush against the basement walls.
k.
2014 Honda CR-V
brirene
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Parrothead_Mike
I don't have an answer for you, but you might get a better response to your question at the Do It Yourself Modifications & Upgrades thread here at RV.net. There are a lot more DIY'ers over at that thread.
2018 Chevy 2500HD Duramax - 2015 Cedar Creek Silverback 29RE
16K Huskey EZ Roller Hitch - EU2000i Honda Generator
