IOTA ITS-50R
Fire19
I have bought a Progressive 50 Amp EMS to install but my problem is how do you get the cover off without breaking something on the IOTA ITS-50R. On the cover it states pull down and out but there is no movement in the cover at all. Has anyone else had this issue and how did you get it off?
Thanks
2000 Ford F-350 Dually Crew Cab
2002 Gulfstream Seahawk 29FKS
1998 GL1500SE
1 REPLY 1
jrp
There may be different versions of that lid, on mine it just snapped off with a bit of prying.
PS: My IOTA ITS-50R went in the trash several years back when that model was found to be the source of several RV fires. A couple of the RV manufacturers recalled their IOTA ITS-50R ATS and replaced them with a different brand. Iota claimed all the overheating and fires were due to loose lugs, but independent investigators found components and wring in that model undersized for the max loads, especially when the AC were running in high ambient temps.
http://www-odi.nhtsa.dot.gov/recalls/recallresults.cfm?start=1&SearchType=QuickSearch&rcl_ID=11V5770...
Jim
