โMay-12-2016 07:05 PM
โMay-15-2016 06:32 AM
โMay-14-2016 05:51 PM
Dayle1 wrote:
How do you overnight w/o shore power and still KNOW you have sufficient battery power for the break away circuit the next morning?
โMay-14-2016 11:09 AM
RustyJC wrote:Dayle1 wrote:
Any trailer with a residential refer should have a dedicated 12v system isolated from the primary battery or a shutoff circuit to prevent draining the primary battery.
Why? The +12VDC wire (pin #4 in the Pollak connector) has no problem keeping the trailer's battery bank charged while we're on the road. If I were running with no +12VDC feed from the truck as some suggest, then that could be a problem insofar as the breakaway system is concerned, but as I've said repeatedly, I would never run without the +12VDC feed being connected. It's there for an important, valid, safety-related reason.
Rusty
โMay-13-2016 06:53 PM
โMay-13-2016 06:33 PM
โMay-13-2016 06:29 PM
enblethen wrote:
Yes, it charges the battery while on the road.
โMay-13-2016 06:14 PM
โMay-13-2016 06:07 PM
โMay-13-2016 04:38 PM
RustyJC wrote:
You can say it until the cows come home. You don't know how much charge is left in the battery at the end of a 10-12 hour travel day, especially in my rig that operates a residential fridge off an inverter while we're traveling. You think I should disconnect MY trailer batteries from the tow vehicle? SMH.
Rusty
โMay-13-2016 12:37 PM
โMay-13-2016 11:34 AM
smkettner wrote:RustyJC wrote:Comment was not directed at your RV but does the battery really die in less than 24 hours? I would have more battery.
Rusty
Only need about 10 volts for 20 seconds in an emergency.
Rusty
โMay-13-2016 11:07 AM
Rusty
โMay-13-2016 11:05 AM
