Is There Such a Thing
JTrac
Probably a long shot here but I am wanting to hook up an Air Lift Wireless One compressor to my new Trailer Saver BD3. I would like to be able to quickly disconnect the air line from the compressor to the hitch so I can remove it when needed. I have looked for a fitting that would attach to the 1/4" air hose from the compressor on one end and screw to the Schrader valve on the hitch on the other end. Does anyone know if there such a thing? I have googled and googled and can't find anything but I may be describing it wrong.
JimT
2020 Jayco Pinnacle 32RLTS, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR
9 REPLIES 9
C_Schomer
I'm not exactly sure what you're doing but you can get double shutoff couplers - shutoffs in both ends. I had a cheapy compressor in my 5er basement and I just mounted it above the pinbox for my 5AB. I teed in and added a second Schrader fitting - one to let air out and the other to leave the compressor quick-coupler connected to and I never disturb it. The compressor valves were leaking a little so I dug thru my toolbox and found a tiny check valve to put in the line between the airbag and the Schrader to the compressor. You can get anything you need from a valve company or pneumatic/hydraulic supplier. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
mguay
Why would you worry about the bags deflating when disconnected? If the line is disconnected...then I would presume the 5er wold be as well? No need to keep air in them!
Yes they do come apart easy!
2007 Volvo VNL 780 D12/Ultra Shift Singled
2017 Smart Fortwo Prime Cabrio
2014 Dynamax Trilogy 3715FB
JTrac
mguay wrote:
My TS3 is on the way. I will use one of these in the line between the compressor and the hitch that will be run across the bed. TS wants you to mount the compressor in the hitch...but I will mount mine in the bed so all I have is the tubing running to the hitch, rather than the tubing and wiring too.
Thanks, that may be what I need. I would hope they are easy to disconnect. Just wondering how to keep the bags from deflating when disconnected from the compressor hose.
JimT
mguay
K_Charles
This site would have a large bore chuck and adaptor.
RoyB
I just googled "air hose quick disconnect fittings" and many sources popped up. I always select 'IMAGES' when I search google for items and then click on the image for more detailed info when I find something interesting...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
K_Charles
Tronair k3706 is a screw on high pressure chuck.
Shadow_Catcher
Ditch the Schrader and use quick disconnect fittings. This is what I did so I can use the compressor to fill tires etc. I ended up have to go to a Triad/Parker Hannifin store http://www.triadtechnologies.com to find what I needed because I also added valves and an assortment of fittings so I could adjust input. I have found the stores very help full.
TakingThe5th
Can you use something like a Milton quick connect fitting with a tee?
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
