Jayco Recall
Tireman9
NHTSA Campaign ID Number :14V775
Manufacturer :Jayco, Inc.Make / Model Years :JAYCO / 2015Subject : Incorrect Tire Label Information/FMVSS 110
Jayco, Inc. (Jayco) is recalling certain model year 2015 Eagle HT FW 28.5RSTS "PR" trailers manufactured June 2, 2014, to October 28, 2014. Incorrect tire size information may be found on the tire label. Thus, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) No. 110, "Tire Selection and Rims for Passenger Cars." CONSEQUENCE:
Replacing a tire based on an incorrect tire size could overload the trailer causing poor handling and increasing the risk of a crash. REMEDY:
Jayco will mail new labels to registered owners with placement instructions. Owners can also request dealers to install the new label with the correct tire size ST225/75R15D, free of charge. The recall began on December 8, 2014. Owners may contact Jayco customer service at 1-800-283-8267. Jayco's number for this recall is 9901229. NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to Home | Safercar -- National Highway Traffic Safety Administration (NHTSA).
You might want to read my information on tire registration and recalls. Just hope you can find it with Google.
40 years experience as tire Design & Quality engineer with focus on failed tire forensics.
8 REPLIES 8
Tireman9
minnow wrote:
Of all the things that need to be improved with RV's, starting with tires that are not built to withhold the weight of the RV and/or temperatures generated, to frames that twist or welds that break, our government(NHTSA) focuses on recalls because incorrect labels were attached to a trailer. Be interested to learn if Jayco took this upon themselves or if NHTSA ordered them to send out new labels. Certainly Jayco knew the labels they affixed to the RV did not match the tires they were installing on the axles.
Usually this kind of "infraction" is quickly resolved as soon as the manufacturer learns of the problem. NHTSA just gets notified, if they didn't discover the issue, and that covers all the legal requirements.
I had this happen with a small utility trailer I bought from harbor Freight. This mistake can easily happen when companies do not have a real QA department that keeps an eye out for this kind of thing.
TXiceman
You will never see Thor or Lippert do something like this.
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
laknox
Most likely the floor workers knew, but were "smart" enough not to say anything lest they be fired. ๐Ÿ˜•
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
minnow
bpounds
Labels
When we were shopping for a fiver, we looked at Cougar 276RL and 278RK models. Ended up buying the 278RK.
Picked it up and the model decal says 276RK. They never made a model with that name. Somebody just screwed up ordering the decal art. I asked for a correct decal but they just blew me off.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
MFL
Nomad II
Nomad II
When I purchased my FW new, I noticed the tire sticker on the trailer did not match the brochure info, or the tires installed. The sticker said 235/80 16D, and the tires installed were 225/75 15D.
I called the factory with the vin, and they said it was ordered with, and left with 225/75 15. They also offered to send a new label.
I had looked at two other FWs identical to mine, both of which had the same 225/75 15D. One had the correct sticker for the tires, and the other like mine was wrong.
Tires do fit the trailer specs as installed.
Jerry
dballentine
I wonder what the original label said.
2015 Grand Design Reflection 337RLS
2015 Silverado 3500HD LTZ D/A CC LB SRW Z71
Amateur Radio KQ3T, licensed since 1965
jerem0621
Way to go Jayco!
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
