JT Strong Arms
Lee185
Just started full timing a few months ago & Im tired of the sway & wobble.
We used our last TT so infrequently it wasnt worth it, but now with 2 adults, 2 kids, 2 big dogs & 2 small dogs we almost need dramamine.
I thought I bought a 5'er not a boat.
I see theres 3 different kits you can buy (191025, 191024 & 191023), also I have square landing gear in the front & round hydraulic in the rear.
Which kit do I need? And What accessories do I need to make it work with my setup?
Nothing worse than waiting for something to be delivered, only to find out you need to order more parts, or worse yet spend extra time & money at Ace Hardware tring to figure out how to improvise a fix.
Thanks Lee
2019 F-250 Crew Cab FX4 Short Bed 6.7L
2019 Dutchmen Atlas 3252 MBF
17 REPLIES 17
BB_TX
I would call them and ask. I would trust their recommendation on the correct part number more than someone on here.
We have them on an older (non hydraulic) 5er and wouldnโ€™t be without them.
Ed9824v
I had purchased a used set at the swapmeet. I called the company and they were very helpful on the install for my application
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
agesilaus
Well the JT Strongarms we ordered came with all required hardware. With one possible exception. If you have to mount one of the arms to thin sheet metal under your RV you may need some metal backer plates to stiffen the mount and spread the load. so it does not deform your sheet metal. Whatever you use I would epoxy it to the inside of the RV basement floor.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
